  #37 (permalink)
Old 04-30-2003, 10:03 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
I have had my car for about 4 years.I'm just now redoing my master switch to overcome a situation that has come up more times than I can remember. I forget to turn off the master switch or plan on only being a second and the heat rises in radiator causing the fans to come on. I come back and get in the car and no battery. Several times I had enough bat to run fuel pump and an incline let me roll and pop the clutch. I tried the battery brain .I had it set wrong once and next time it just gave up after draining my battery and never did work at all again. I'm installingm a Flaming River combo switch centered in dash. Twist on, just push in to disconnect.
How about getting all belted in with the latch type belts and then can't reach the master switch. Hey stranger lean in here and turn on my master switch .You realy have to lean in and reach under dash. Yes there realy is a switch there. Thanks.
Mike H
