I saw a television program which showed the testing procedure that Lakewood uses. They build a saw blade into the test housing whch cuts through the clutch or flywheel while it's spinning at maximum velocity. The explosion is pretty loud but only causes dents in the 1/4 inch steel plate of the scattershield.
Paul
