Old 05-01-2003, 08:33 PM
Bud Man's Avatar
Bud Man Bud Man is offline
Cobra Make, Engine: Former Owner/Builder of KMP142 427 Sideoiler, Tunnel Wedge, Aluminum heads, etc.
Tommy:
I have a 427 SO mated up to a toploader and installed a McLeod Hydraulic T/O Bearing assembly. This bearing replaces the mainshaft's collar, and yes, it is bolted to the transmission.
I cannot understand why you cannot extract your transmission from your bellhousing as the diameter of the T/O collar has to be small enough to pass thru the hole in the bell.
I know several folks who have installed their trans and bell as a unit, but I would not recommend it as it does not allow you to check - and if needed - adjust the fit for mainshaft concentricity. Such adjustment is most always needed for a Lakewood.
Take your time and work the trans out of the cavity, making sure that the master cylinder and bleed lines are not hanging up
When you do finally get to the T/O its a good idea to check all seals and o-rings for deterioration, and replace if needed.
Bud
