Old 05-02-2003, 05:54 AM
Steve Jones's Avatar
Steve Jones Steve Jones is offline
Club Cobra Member
If the throwout bearing is a McCleod, then the hoses attach to the bearing using banjo fittings. They need to be swiveled around to the front (parallel to the input shaft) and removed with the transmission. You do have the pressure hose detached at the master cylinder don't you? You might also check for any hose (Adel type) clamp that may have been used inside the bellhousing to keep the hoses out of the rotating assembly.
Steve
