Old 05-03-2003, 06:36 PM
ENTDOC's Avatar
ENTDOC ENTDOC is offline
You have a hydraulic throwout bearing.These are known to leak and are of course a pain to fix.The tranny will have to be dropped to fix or replace.This is no big deal if you have the inclination but it takes time and a lift is nice.I would suggest replacing with a external slave cylinder from autoworks or other source;it is a simple install and a simple fix if problems pop up.The bad part about your problem is it probably is a 25 cent o ring that failed. chuck
