Old 05-03-2003, 08:58 PM
ENTDOC's Avatar
ENTDOC ENTDOC is offline
It is used very commonly,in fact I have a new one I decided not to use after hearing the down sides.It is a very simple system and can work very well but I dont like to pull trannys so I went with an autoworks unit;10 minute install and adjustable.You do not need to change your mastercylinder or your plumbing for the most part just make sure you match up bore size of master and slave for best pedal feel.Remember they are both hydraulic but you will need to pick up a clutch arm to attach to slave cylinder and also a new throwout bearing( 10 bucks at autozone) chuck
