Thread: Spf Rollbar
Old 05-05-2003, 07:38 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Remove the cross bolt from the long "forward right" hoop leg. Remove the angled leg that goes into the trunk, remove it's mount as well. The short leg that mounts over the coil spring, just slides down over a nub on the frame, no bolt to remove there.
So remove the rear bar so it is just a hoop, then pull hoop straight up, it can be a little difficult, sometimes they want to be tapped in 'out with a deadblow hammer, using a towel as a buffer.
