Old 05-05-2003, 02:26 PM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Mike,
My Cobra started out with a 302/T-5 trans and did NOT use either (internal or external) hyd assistance. I was not running the strongest pressure plate avail either but I was using a medium duty ram clutch set up. My HP was about 330.
I am running a hyd t/o brg now because there is not enough room between my bell housing and frame to use a conventional clutch-clutch rod-throw out bearing set up. I am not a big fan of my set up either. So, unless you just can't push your clutch in and hold it in at stop lights I would not use either method. Besides you get a better feel of your clutch without assistance. Another plus to NO HYD Assistance is that it will keep your wife out of the drivers seat too.
Clois
"Let's roll"
"Be part of Something Good
