Old 05-05-2003, 02:18 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
You guys are doing a bigger disfavor to your engine by introducing a large airpocket. There is very little oil capacity % wise in the cooler. You change your oil too frequntly anyway. You can never get all the oil out of a motor anyhow when changing it. If that last 1/2 quart is such a big deal, then right after changing the oil, why does it look so fresh and yellow? I am yet to hear why it is bad to mix viscosities of oil, in an engine, from an engine builder. I think it's more important to just have fresh oil that is warm. Keep it yellow, and let it get hot before you stand on the loud pedal.
