Old 05-06-2003, 06:23 AM
M. Farcus M. Farcus is offline
I've torn up a few....mostly from drag racing which I don't do anymore....
I've run up to 500 hp thru a single disk adjustable pressure plate, mcleod unit, 4 blade puck brass puck type with spring center....on aluminum flywheel with steal insert...chatters a bit after its hot...but not to bad..ok for street. Mecleod made the disk up for me...its not in the catalogue with a sprug center...or least it wasn't..haven't looked in years....Call Red at McLeod...or David Kee.
I've also installed the mcleod street twin in several cars...works fine but rattles a bit when in neutral and also heavy in my opininon but will not slip.
Currently for road race only I'm using a QuarterMaster 5.5 triple disk...nice unit, very "on/off". Would not recomend it for the street....you "can" feather it, but it is not good for clutch.
M
