Old 05-07-2003, 09:07 AM
PSB's Avatar
PSB PSB is offline
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
Mark,
It's quite easy to remove all the smog stuff, especially if you go with carb(s). If you opt to stay with the EFI, you can still remove all the smog gear and replace the solenoids/sensors in the wire harness with some resistors.
All the information you could ever want on upping the power of a Ford 5.0L engine can be found at the Corral.
Pete
