Old 05-07-2003, 12:17 PM
TampaRMC TampaRMC is offline
Talking Exhaust (header Gaskets...)
You just need to drop the header ... you dont need to take apart the entire exhaust... you should be able to losen
the bolts on the head ends (removing the middle ones) and pull the gasket out. If you want you can clean up the surfaces with a scraper but its not necessary. Then get a new gasket with the "end Hooks"; there designed so that you DONT have to drop everything to replace them. THAT way you keep your side pipes hooked up and there give, gives you enough slack to change the gaskets out.
Think about it... you think you pull an entire OEM exhaust to pull the gaskets or for that matter the heads. Don't make this harder than this is.
Rich
I want to build the best driver I can... for now... (OK that's what I told mama... now its a stroked 347!!!, trickflow, airgap, msd.... you get the picture... I hide the bills!!!!... delivery of engine January 03!!!!
