Old 05-07-2003, 02:18 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Originally posted by Corky
I had to clean of the heads as the former owner used casket seal.
What did you buy it from an undertaker?
I like the blue fel-pro header gaskets. I don't do the water soak trick on the fel-pro's. The paper/aluminum ones are junk. Watch the header bolts, they need to be tightened every once in a while. Keeping them tight will prevent the need to replace the header gasket.
