Old 05-07-2003, 05:31 PM
Tony Radford's Avatar
Tony Radford Tony Radford is offline
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Interesting tips. I purchased a set of copper gaskets, milled out the exhaust port openings (heads are ports were opened quite a bit) and installed them with the sealant provided by the gasket manufacturer-Specialty Component Engineering. They're not "hooked" so I had to remove the headers. It really wasn't much of a problem. They really have to be tight to prevent backfiring between shifts. I've gone through and tightened the header bolts three or four times between rides. I hope it just takes time for them to seat. If not, I'll replace them with something else. I hate backfiring.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
