Old 05-07-2003, 06:57 PM
Bannon's Avatar
Bannon Bannon is offline
Cobra Make, Engine: Former Owner of both Superformance #2666 Roush 427IR and Superformance #1601 Ford Crate 460CI - 486 HP 510 ft\lbs TQ
Question Timing Gun with Battery in Trunk?
OK, My new Superformance is running rough and backfires if I stab the throttle at idle. I was told that the primary culprit was bad gas or winter gas. The problem has been getting progressively worse through the last 3 tanks of gas. The last one I got from an Amoco out of the city (to try an get non winter gas) and included a bottle of Octane boost. I have tried to richen the idle mixture slightly but still not any better.
I'd like to check the timing but as I was pulling out my timing light it occured to be that with the battery in the trunk it wouldn't reach. Is there anywhere under the hood I can hook it up to get power? maybe the starter soleniod or something?
Also I know with a vacuum advance you need to need to pull the vacuum hose on the distributer to check the timing at idle. My car appears to have a mechanical advance. Is the enything special I need to do?
Thanks
John Bagley
GUMBALL!
