Old 05-07-2003, 08:42 PM
fw209's Avatar
fw209 fw209 is offline
Cobra Make, Engine: It WAS a B & B 306, T-5, narrowed 9" - 4:11... Hope to replace it soon.
Default Switch
Tom;
If by chance can you go to a GM style switch? I attached a link to a picture of my ped box with the switch in it.. It is very simple and easy.. KEM PART NUMBER EG-1072. $ 5.84...If the parts store by you doesn't carry KEM parts they should be able to cross it over for you.. I attached a link to a picture of mine.. I just drilled a hole in the front of the ped box and installed a small grommet then fed the wires through.. Mine works just fine. I also have the Haywire harness too... Hope this helps you out.. BTW you can use the same switch to make a clutch safety switch using your neutral safety circut..
http://groups.msn.com/Freds1stCobra/...oto&PhotoID=36
Getting ready for the next build. Got the 351W on the stand.
