Thread: Spf Rollbar
Old 05-08-2003, 01:07 PM
craigayl's Avatar
craigayl craigayl is offline
Cobra Make, Engine: Superformance Cobra SC, 514CID
Removing the tunnel makes it easiest to replace the shifter, but it can be done without removing the tunnel.
First remove the shift lever (4 small bolts), then the 6 bolts holding the shifter in. The two forward most are the biggest chalange. then remove shifter from under the car. The new one in installed in the reverse order.
