Old 05-08-2003, 03:04 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
A few differnt things determine the max rpm a motor can see. One is how much RPM can the shortbolck handle before it lets go, this is determined by what quality parts you have for crank, rods, pistons, fasteners and bearings. The usual rpm limiter is the valvetrain. The valves will float and power will drop substantially. Revving it to a high rpm is only faster if your cam is ground to make power at high rpm. Not to mention the heads, manifold, carb etc have to be in a configuration to optimise high rpm flow rates. Your combo should be fine to 6000, reving it higher will probubly not make you any more HP. as it will probubly be falling off by then.
