Old 05-08-2003, 09:57 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Sounds awefully cheap. Check it out good. Solid roller on the street is very questionable. You should pull the lifters every 4,000 miles or so to check for roller and roller bearing wear. If one lifter lets loose, its all over.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
