Old 05-09-2003, 08:25 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
If you aren't going to spin the motor to the RPM where the cam is designed to make power, why not run a less duration cam? You'll get more torque and often more HP with a smaller cam, especially if you don't turn 7000+ rpm. Big duration cams NEED higher compression to work right.
