Old 05-09-2003, 07:53 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
The marine 427's as put in CrisCraft's in the late 60's were 427 SO blocks drilled as centered oilers. The side oiler galleries were left unmachined. These 427 's can be changed and drilled out to side oilers for several hundred dollars. But, I heard, that sometimes when ford was maching a 427 so block, and machined too deep into the side of the block for the engine mount, machining into the side oiler gallary, they then used this engine as a marine engine. So, not all marine 427's, even though cast as a side oiler block, have enough meat to be drilled out as a side oiler.
I almost bought a pair of these engines, for $2500, but at the last minute, the guy changed the price to $3500. These engines were used in fresh water, but that still doesn't guarentee that they still would be good, and not rusted out.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
