Old 05-11-2003, 08:49 AM
my427cobra my427cobra is offline
Club Cobra Member
Cobra Make, Engine: NAF 427
Hi gumball. I have taken a number of measurements off of various original cars and here is my best approximation : Large radius is 6.5" and small radius is 4" , total length is 17". The bottom is straight from "circle to circle" while the top is curved in parallel with the curve of the top of the dash/cowl. The trick is where is the glove box located ? Again , my best approximations from measurements taken : the big end is 6" from the vertical centerline of the dash and the bottom is 1" up from the bottom of the dash, resulting in about 1" between the top of the glove box curve and the cowl curve.
You will notice I use approx and about. Cars seem to vary + or - 1/8" and it depends on the thickness of the dash cover and welting used on the edge of the door.
Furthermore , every replica is slightly different so a match with an original car will be at best approx.
The handle is available from Bill and Marge at Motorsports International , although many cars have been refitted it a locking pushbutton mechanism.
If you send me you mailing address , I could send you a paper template.
Greg
