Old 05-12-2003, 09:41 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default Motorcycle vs Cobra
In my experience, high performance street bike vs high performance cobra (my west coast) the cobra brakes much better in general (admittedly with some large power discs all around) Much of this is also due to the larger contact patch and the sticky Pirellis. This would be much more so on wet pavement.
A bike (Or car) gets most of it's braking power from the front brakes, and this, on a bike is a tenuous, unstable, small patch of rubber to clamp a pair of disc brakes onto in a crisis. Add road sand or grit and a bike loses it completely. Mayhaps the apparent better traction on motorcycles with higher HP/weight ratios is due to the relative weight ratio on the rear tire, vs a car? Someone could do the math and see if that makes sense. But it seems with similar power to wt ratios, a bike has a bit better traction off the line, and does not seem to "lose it" as easily when opened up fully in a corner. Could be bike geometry also ?
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
