Thread: John-tucson
Old 05-12-2003, 10:28 PM
John-Tucson's Avatar
John-Tucson John-Tucson is offline
Hey Mikec, I got the Cobra back today. Two relays were replaced, the computer relay and the A/C relay, which is being used as the fuel pump relay. All of the internals were good on the computer. He could not duplicate the starting problem that I was having, thus the replacement of the two relays. He fixed the water temp gauge, the sending unit was bad - that's the fourth one !!! The gauge is inaccurate because it reads 230 degrees when a temp infrared sensor reads 200 at the sending unit. WHATEVER !!! He reset the timing to 10 degrees, after MikeF and I messed with it up there in Phoenix, but I'm getting a lot of pinging at 2000 RPM. Also, he reset the shift points for the transmission and it seems to operate much smoother. Yes, Mike I'll be in Phoenix BUT I WON"T TELL YOU !!!!!!!!!!!!!!!!!!!!! I know that with the heat starting to build during the day that early morning departures are necessary, however, none of us Tucson guys can make Wickenburg by 9:00am, that would mean a 5:45am departure from Tucson. If you can make a run to the southeast of Phoenix, toward Globe, at a reasonable hour we'd be glad to join up with you. John
John
