Old 05-14-2003, 06:12 AM
C Man C Man is offline
Location: Winnsboro, Texas-outside /south of town, two hours from dallas,
Default 83 Glaspac Cobra Tranny
Is there an owner of an oringinal Glaspac Cobra which came off the assembly line with the original small block and four speed tranny. Much research has not revealed the tranny make. This is a four speed with only two shift rods. One works off a vertical shaft coming out of the tailshaft housing, the other off a horizontal shaft through the main unit. There are two side inspection covers on this unit. One on the main unit, the other on the tailshaft housing. This tranny now requires syncro replacement after 20 years and I would like to determine if parts are available. In todays terms this unit would look like a side loader T5 combo except that it is cast iron. The early style bell housing is utilized. Sound input will be appreciated.
C Man
