Old 05-15-2003, 07:25 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
I bet you have Willwoods and 15" wheels, right?
The parking brake "spot caliper" will rub. You need to knock it down some with a sander. I use a 90* die grinder with the 3" sandpaper disks in 150 grit, it takes just a minute, then spray paint the caliper flat black again. Trial fit of course before saying you are done.
