Old 05-16-2003, 06:09 PM
khall khall is offline
Cobra Make, Engine: Superformance #1231 428 FE
I talked to a couple of our local vintage experts today and they said that the two different camber suggestions are related to bias ply vrs. radial ply tires. The radials are more sensitive to camber changes and the rule of thumb is .50 to .75 degrees of negative camber for them with the larger numbers for bis ply. Makes sense to me.
So I set my front at -0.50 deg camber today with 5.5 deg positive caster. Actually, I found that you have to disconnect the steering arm to change the caster. I originally had over 8 deg positive on both sides (my bubble gauge reds 8 max.) So now I am trying to set the tow. My vintage friends suggested that I set 1/8" tow out to help corner turn in. So I put a piece of tape on each front tire and measured both front and back. No luck. I assumed that the measurement would be taken at the tire surface but one turn of the steering arm = 1/4" change at the tire. Hmmmmm. So where is the measurement taken?
Keith
