Old 05-17-2003, 06:26 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
George,
If the dye test doesn't work, find a shop that can do a "smoke test". This is the newest way of finding leaks in any engine system, be it oil, coolant, refrigerant or whatever. Smoke can find smaller passages to get out of an enclosed system than does any liquid without making a mess, so smoke would be your best shot at locating your troublesome leak.
In your situation, I suspect they would inject the smoke into the crankcase and study the area immediately around where you suspect the oil is coming from. It shouldn't take long for the leak to be pinpointed.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
