Old 05-18-2003, 08:42 AM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
You can't go wrong with an Ididit steering column. Allthe appropriate bells & whistles, and not wildly expensive. That's what I used along with a LeCarra steering wheel. Turn signals, emergency flashers, dimmer switch, and horn on column. And it's a tilt column as well. On a CR, tilt is necessary. If you don't need the tilt, I have an Ididit spare at a very reasonable cost. Wrinkle black, same as the wheel.
Think Enzo has more original looking ones, could check.
For a CR, DV has a custom made one that drops right in.
