Old 05-18-2003, 12:50 PM
aumoore's Avatar
aumoore aumoore is offline
Cobra Make, Engine: Hunter 427, 5.0 (302)
Try an old VW steering column before they put the key in the column. You can loosen one screw and put the turn signnal lever on the right side which is proper for a cobra.
I bought an old billet aluminum column and a new signal lever(about $65 from a VW parts dealer). The VW has a 7/8" shaft so I had to get a custom steering nuckle from borgenson. between the steering rack and shaft I have a 3/4" DD shaft.
This is a cleaner look than a GM column but if you want tilt you might go with a Ididit
Click here for DSCC website
