Thread: Rock Chips!
Old 05-18-2003, 01:00 PM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
bly
As with all Cobras, mine also suffered with rock chips to the rear fenders. So to put a stop to this nonsense, I contacted Invinca Shield in Wilkesboro, NC. After toting my car over to Wilkesboro, I now have protected fenders. Mark Elliott did a great job installing the 3m Clear Sheet. If you didn't know it was there, you couldn't find it. So what if you can. Sure looks better that those nasty paint chips.
Check out the attached photo and try to see the edges of the clear sheet. It follows the door opening from the upper corner down to the bottom of the rocker panel, wraps into the wheel opening and goes up the fender and back to the upper corner of the door.
I'm ready for DVSF III, sticky tires and all.
When time permits, I'll have the front end done, too.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
