Thread: which cam shaft
Old 05-18-2003, 10:23 PM
cobra427mnsi cobra427mnsi is offline
Cobra Make, Engine: Classic Roadster with 427 center oiler
FE Specialties
The FE that I bought has all the machinig done. It just needs to be put together. Below are the specs for cam, heads, springs etc. I received these numbers just as they are from the owner. I sort of understand them but not as well as you probably. Could you please advise me on the cam. Is this cam streetable with a reasonable horsepower rpm range. Will it make some vacuum? etc.
Any input from you would be greatly appreciated.
Thanks,
Paul
427 L/R heads:C3AE #0609, 219/177 stainless valves, k-motion
triple roller springs,titanium retainers
427 steel crank: C5AE, ground 10/10
427 lemans rods: C6AE, bronze bushed,shot peened,arp bolts
Arias forged 10-1 comp pistons with file fit rings
Crower solid roller 640/654 lift, 254/260 dur @ 50,114 lobe sep
Ati balancer/Sealed power flexplate
life is short: eat dessert first !
