Old 05-20-2003, 01:33 AM
Turk's Avatar
Turk Turk is offline
Cobra Make, Engine: What Cobra?
Send a message via Yahoo to Turk
Default Fe Garage Sale.!!
I have the following items for sale.
427 4V TUNNEL PORT INTAKE-New Old Stock-
Brand new in the factory box. This is a SINGLE 4V intake.C8AX-9424-B.
This has not been cut, drilled, welded, or modified in any way.
$1000.00
ORIGINAL FORD 427 TUNNEL PORT AIR CLEANER
Factory Original Ford Dual 4 BBL Air Cleaner. Came off a late 60s Torino. Excellent Condition.
$250.00
FORD 427 SIDEWINDER INTAKE MANIFOLD
Designed for a 427 Medium Riser Engine. Number is C6AE-9425-K. It will fit a Low Riser and a Medium Riser, and the 428 CJ heads on any FE. Dual Plane design should give maximum low end power and the offset carb pad equalizies runner lengths for maximum top end power.
$650.00
427 SIDE OILER SERVICE BLOCK-New Old Stock
The block was in cosmoline and in box. It may very well be still in the box as we speak. It is sitting at George Anderson's at Gesford Machine in Hastings Nebraska. It was cleaned and magnafluxed and sonic checked. There is minimal surface rust. Should clean up well. It is standard bore, never been used. There are two issues with the block, that George can explain better than I can. One of the threads for the main caps is not deep enough for George's taste. He suggests it be helicoiled. Also there are two main caps with identiacal stamping on them. Other than that it is a brand new block. No sleeves, no welds, no repairs. If interested, I will arrange for George to explain the block in machinist terms. Please do not call him asking about this block, unless there is a serious interest and we have agreed on the terms. Then I will arrange him to talk to you.
$5500.00
427 TUNNEL PORT HEADS-Excellent condition.
C70E-6090-K
Heads are lightly ported and polished.
$2000.00
MATCHING INTAKE FOR ABOVE TUNNEL PORT HEADS- Excellent-
C70E-9424-A
2X4 Tunnel Port "Tunnel Wedge" Intake.
$1000.00
NOS FE TUNNEL PORT HEADS-New Old Stock
Pair of assembled NOS Tunnel Port Heads and 8V intake.
Casting #s. C7OE-6090-K and Holman & Moody Nascar 8V Intake C7OE-9425-A
These heads and the intake were assembled by Smokey Yunick for Richard Petty racing and never used. They are very streetable (ask Bill Malone).
Will not separate them. They have the streamlined guides rather than the round lifter guides.
They are a matched set.
$3500.00
Well guys, I suppose I could have put these on the eBay, but I don't want to. I would rather know who I am selling them to, and would like to see them go to a good home.
They are located in Northern California, and would be great if I didn't have to ship them.
Why am I selling them? Because I don't want them sitting here gathering dust. I have my motor, and if I need any spare parts I can buy them back from you.
You can reach me via email
ate@chevs.com
TURK
OBAMA IN in 2012
