Old 05-20-2003, 04:13 AM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
The 302C block is the same as the 351C block. The bore is the same, the difference is shorter stroke crank and 6" rods. 351 rods are 5.778". The Cleveland Crank and rods are good strong items. All factory cranks are Nodular Iron, there wasn't a factory steel crank but the High perf Clevlands had cranks with a higher nodularity. The stock crank is plenty strong, the guys drag racing them are spinning them to 7 grand plus with no problems. All factory rods had 3/8" bolts and I would reccomend polishing the beams, shot peening them and a set of good ARP bolts. They should be good enough for a very healthy street motor.
Don't confuse the 302 and 351 Cleveland engines with the 302 Boss motor. The 302 Boss is basically a 302 Windsor with the higher flowing Cleveland heads on it. The Cleveland block is quite different to the Windsor.
A lot of guys when it comes time to rebuild their 302 Clevelands swap the crank for the 351 item. They are cheap and plentiful down here. You can then pick up some ACL pistons to match the rods and crank (need new pistons anyway). There are forged short compression height pistons available too. The longer 302 rods combined with the shorter comression height pistons make for a stout performing, revy long rod 351.
The 302 generally had closed chamber 2V heads which can result in unreasonably high compression ratios for a street motor. Some head work to open the chambers up a bit and de-shroud the valves helps. 2V heads work well on the street, the ports in the 4V heads are just too big plus they don't flow as well as they could because of the port angles. A set of Aluminium 3V heads from CHI would realy wake the motor up. With the Aussie dollar the way it is they would work out quite afordable to our US brothers. Compare how much you would spend on rebuilding and porting a set of factory heads when these flow 650HP plus out of the box!!
Top it all of with a TFC or a Funnelweb intake manifold and you will be scaring the big block boys.
Mike Murphy
Melbourne Australia
