Do It!
This is the way to go if you are using 17” wheels. You’ll want to use the Tremec II (525hp or less), TKO II (for over 525hp or drag racing), and the 3.08 rear. It makes for a prefect close ratio gear set up. 5th gear road speed is the same as with the 3.73’s. But the first four-gear speed moves up. Makes the gearing more useful on the street and the track (road race). I just wish, I had known from the start. I would’ve gone this way originally.
Hope this helps you make a decision.
Lew
