Old 05-21-2003, 10:23 AM
XXQQQME's Avatar
XXQQQME XXQQQME is offline
Cobra Make, Engine: West Coast, Ford 460
I believe that there are two ports on the throw-out bearing. One inlet and one outlet. It doesn't matter which is which. One is connected to the slave cylinder operated by the clutch pedal and the other is used to bleed the system. On mine, I've tie wrapped the two lines out of the way so the clutch does not rub against them (could cause clutch to fail). On the end of one of the braided lines I've installed a bleeder valve. It will take two people to bleed the system. . . one to depress the pedal and one to open and close the valve. I usually pump up the system with the pedal and then open the valve and catch the fluid in a jar or can. I do this 3 times.
Good Luck!!
'bacher
