Old 05-22-2003, 04:53 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
There is a wire to either the starter, or starter solinoid. You will want to interrupt that wire and have it go to a relay controlled by the transmission and then to the starter/solinoid ( no taking off for spelling ).
When the transmission is in neutral, the relay closes and allows current to flow to the starter/solinoid. If the trans is in any other position, the relay will not close and the starter can not be engaged.
You want to use a relay for two big reasons; service and protection.
Hope this helps.
Trularin
