Old 05-23-2003, 05:09 PM
Daniel Jones Daniel Jones is offline
> Does anyone have any experience or knowledge about the 351 Cleavor?
Yes, I have one that is forming the basis for a stroker motor for
my Pantera.
> It's supposed to have the best of both worlds of the 351 Cleveland and
> 351 Windor like bigger journals,
Actually it has the Cleveland's smaller diameter main journals.
Smaller journals mean the oil is at lower speed for a given diameter
which is good for lubrication.
> wider pan rails to support a 4.25 crank,
Yes it uses the wider 351C pan rails.
> Windsor oiling system, etc.
The internal block passages are designed like a Windsor but the oil pump
and pan are 351C parts.
> How good and reliable are they?
I can't say anything about reliability yet as I have to build my engine.
However, there are several Pantera owners running them that I know of and
I haven't heard of any real problems. One guy I know did have problems
with his because a machine shop attempted to align-hone the main bores
instead of align-boring. This ovaled the mains as the hone removed more
material from the aluminum block than from the iron main caps. With a
rigid cutter, align-boring cuts equally from both. The same guy also
noted that dowel pin location was off on his block (or was it the cover?)
> Why haven't they been more widely adopted if they are so good.
They weren't really marketed for street cars. They were designed as a
race block for sprint car use, back before any of the Ford Motorsport
or Dart race blocks were available. They've found their way into drag
cars and street cars (primarily Panteras) since then. Originally, the
price tag was quite high. When they were introduced in 1985, they were
$4100 but the price has come down in recent history due to competition
from Ford Motorsport. Fontana also makes other racing blocks, including
a 4 cylinder aluminum block used in certain sprint car and boat racing
classes.
> A company called Fontana Automotive who created the aluminum
> Cleavor block in 1985 is selling the block for $3750 which seems
> like a pretty good deal.
- Available in 9.2" (Cleveland) or 9.5" (Windsor) deck heights.
Mine is a 9.2" deck block.
- Siamesed bore (dry wall, ductile iron top hat cylinder liners, interlock
with flats on sides between bores). Absolute maximum bore is 4.155",
though 4.125" is probably more likely (sonic test to be sure).
- For large diameter bores, recommended headgaskets are Fel-Pro 1022
(left hand) and 1023 (right hand). These gaskets have 4.160" bores,
are notched (one has 2 notches, the other 3 notches) and come with
instructions. Use Fel-Pro 1021 for bores up to 4.1".
- Clearanced for standard full size starter (I'm using a mini starter)
- Compatible with solid or hydraulic flat tappet lifters and solid roller
lifters but does not have the tall bosses for OEM hydraulic roller
lifters (could use the retro-fit reduced base circle stuff)
- 4 bolt main caps on all 5 mains, splayed on 2, 3, and 4.
- Windsor rear intake manifold seal rail shape (requires SVO or Edelbrock
dual end seal style intake).
- Windsor oil system layout
- 2.750" main diameter (for Cleveland diameter crank), though I think
Fontana will bore to 3" Windsor mains if requested.
- 351 Cleveland main bearings
- 351 Cleveland oil pan and gasket
- 351 Cleveland oil pump and pick up
- 351 Cleveland cam (13726548 firing order)
- 351 Cleveland cam bearings
- 351 Windsor distributor with Cleveland gear
- 351 Windsor timing chain
- 351 Windsor timing cover gasket
- 351 Windsor water pump ('70-up)
- 351 Windsor end seals (intake end rails)
- Small block Ford lifters (same for Cleveland or Windsor)
- Small block Ford motor mounts (same for Cleveland or Windsor)
- Fontana specific front cover (included), optional sprint car front cover.
- Custom length pushrods
- Screw-in, O-ringed, Allen head core plugs
- Studs/bolts for block and head combo (available from ARP or Fontana)
- Can be plugged at oil filter or oil pump base for dry sump (remove
for wet sump).
- Has wet sump provision but is currently plugged for dry sump (need to
remove one plug).
- Has pad for internal oil pump (not just external wet sump).
- Ford Motorsport Cleveland-style canted valve aluminum high port cylinder
heads (A3/B351/C302/Yates) require water passages be plugged like a
Windsor block (per SVO cylinder head instruction sheet).
- Windsor cooling system (Windsor thermostat in manifold or remote
thermostat, not Cleveland in-block thermostat).
- Drilled for hydraulic of solid lifters. Can use hydraulic flat, solid
flat, or solid roller. Lifter bosses not tall enough for OEM hydraulic
roller (could use reduced base circle retro-fits).
- Lifter bore angles are non-stock
- Bare block weight = 116 lbs
- Per Super Ford magazine article on Pantera engine, assembled engine weight
is 404 lbs (Fontana block, high port heads, Ford Motorsport intake).
Torque specs:
Head studs 115 ft-lbs
Main Studs 1/2" diameter 100 ft-lbs
Main Studs 3/8" diameter 35 ft-lbs
Main Studs 7/16" diameter 55 ft-lbs
Run head studs into block with 10 ft-lbs maximum. Apply light coat
of silicone RTV on N.C. thread of head stud. Re-torque head studs
after initial running. Engine should be at room temperature for
re-torquing.
Instructions to Restrict Oil to Lifter Galleys on Fontana Clevor block
(see illustration of rear of block):
1. Tap 7/16"-14 through rear lifter galley openings. Stop before threads
reach lifter bore or when nose of tap appears.
2. Clean block and install set screws, 5/16" long, 0.073" hole, and use
Loctite.
Basic Instructions for Cleavor Block (already performed on my block):
1. Deburr and polish interior surfaces of block
2. Bore sleeves to size
3. Hone to final size
automatic hone - use Sunnen JHU625
hand operated - use Sunnen AN501
finish should be 14 to 23 RMS
4. Match up water coolant passage holes in block to holes in head gasket
by hand grinding block.
5. Install torque plate to seat sleeves
6. Deck block.
General Notes:
Joe Fontana recommends the main bearing clearances be 0.0015" to 0.0020"
cold (will grow a 1/2 thousandths hot).
Roush pins the cam bearings from the top on his race motors so the cam
bearings do not walk fore-and-aft (material is relatively thin there so
be careful). Roush also helicoils the mains.
Aluminum expands more than iron. The aluminum block and heads can expand
by more than 20 thousandths when hot. Note that this is more than the lash
on a "tight lash" solid lifter cam (required lash of 16 thou is less
than the expansion). You need to set the lash hot.
Miscellaneous Notes (Pantera-specific):
351W waterpump on Fontana front cover will position the pulley in the same
spot as Cleveland and has water outlet on same side but new accessory
brackets will be needed (Windsor type to match the front cover).
Will need to custom fabricate a thermostat housing to coolant pressure
tank pipe.
Hope this helps,
Dan Jones
