Old 05-23-2003, 04:11 PM
Daniel Jones Daniel Jones is offline
> Have a 351C 4V with Edelbrock Torker and Holley 750cfm. Is the general
> consensus for my engine that Blue Thunder intake manifold is 'best'?
Best is dependent upon the rest of the engine and what it will be used
for. The Holley Strip Dominator is the best horsepower intake and works
smoothly across the rev range if the carb is properly sized and set up
(with a lumpy cam and single palne intake annular boosters are good, as
is a MSD multi-strike ignition). The Blue Thunder comes in second.
Both are better than the Torker. All three intakes were tested on a
friend's 377C stroker by his engine builder. Do not use port stuffers
with big port intakes unless you fill the intake port floor to match.
There are also some new race intakes from Australia but I have not used
them.
> Has anyone tried the MPG Cylinder Heads port plate kits which restrict
> exhaust ports?
Not personally but I've been told by guys who have run them, they don't
work well if the header turns down at the exhaust port. On something
like a Cobra or a Pantera which have straight pipes out of the ports,
they might work and are worth a back-to-back test. One Pantera guy I
know ran the Stinger inserts and said they helped.
Dan Jones
