Old 05-23-2003, 05:27 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Not sure it needs to be this complicated. On a CR, wire #121 runs from the ignition start to the starter safety switch on the trans. Wire #126 runs from the trans neutral safety switch to the starter solenoid.
Plug the trans wiring harness into the trans neutral safety switch and backup light switch, and you're done.
That being said, CR also had to accommodate those using automatic trans's. You may have to locate the AT 121 - 126 connection and jumper it.
