Ike,
If you're using my MSD wiring recommendations, are you connecting the yellow and white ballast connections (#43) together?
If you're not using an electronic ignition, check the yellow #43 with the ignition on. It should be live. If it isn't, I'd check the IGN terminal on the ignition switch first, then the block connection between the front and dash harnesses.
Bob Putnam
- E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
