Old 05-25-2003, 07:10 AM
mr bruce mr bruce is offline
Bwanna, now you see what I mean. Now take a look on the autocross forum. The thread is about the Atwater event. Dave B is lowering the upper balljoint adapter. Effectively turning the spindle into a Mustang 11 height spindle(?)Then ,when you roll the top of the spindle back to get you desired caster, the steering arm is on an angle relative to the ground.Ideally ,you would want the steering arm(where the tie rod end bolts on) level with the ground ,No?
