Old 05-25-2003, 07:03 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Art, you did make the factory CR sidepipe muffler conversion to glasspacks before coating, didn't you?
Rear wiring harness isn't that big of a deal. You can follow the factory wiring diagram and make your own harness. You don't need all those plugs, because once plugged in using the factory harness, there is no reason to unplug anything. Solder, crimp, and hardwire all connections. I had to make a second rear wiring harness for all the extra stuff I put in the back. I can help dance you through if you'd like.
