Thread: Any Dyno Gurus?
  #44 (permalink)
Old 05-27-2003, 06:01 PM
A Snake A Snake is offline
Cobra Make, Engine: Contemporary CCX33868 Sold. Just "playin' the boards now."
Here's engine dyno #s from my 427 S/O
hp 485@ 6,100rpm
torque 490 lbs/ft @ 3,900
FYI the numbers didn't cross at the "magic" 5252.
As to the high rpm Indy type engines, I would suggest that two thing be taken into account. First, they are not "normally aspirated", meaning they are stuffing air in with turbos or superchargers. Second, they have a bore and stroke ratio that would scare you. They often have less than a 1 1/2" stroke. Those engines rely on airflow/manifold pressure and rpm to make hp. 320 lbs of torque doesn't sound like much, but 853hp will break tires loose at 200mph.
Al
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
