Old 05-28-2003, 04:03 PM
BANDIT 1 BANDIT 1 is offline
Default This is from the Shelby SIA websight...
SHELBY COBRA CSX4000
The Shelby Cobra is arguably the world's most famous and recognizable sports car. The legendary 427 S/C was the ultimate expression of this incredible car. Today's CSX4000 Series 427 S/C Cobra from Shelby American is everything our 1965 model was, and more. From the world's first computer designed chassis and four wheel coil-over independent suspension to the heart stopping power of the big block Ford V8 breathing through those awesome side pipes - these Cobras are all Shelby. The authenticity is documented by Shelby CSX chassis numbers and a Manufacturer's Statement of Origin (MSO) from Shelby American signed by Carroll himself. Improvements include a stronger steel frame and better alloys used in the components, plus better cooling and additional heat shielding to make these cars safer and more drivable without losing any of their original character. If you've ever wanted a true Shelby Cobra, this is your car. With 0-60 in four seconds flat and 12 second quarter mile performance, you'll know exactly what it's like to drive a true American Legend.
All new production Shelby Cobras are offered in component form, less drive train.
GENERAL SPECIFICATIONS
Vehicle Type - Two Passenger, Two-Door Roadster
Dimensions and Capacities:
Wheelbase - 90.0 in.
Track, F/R - 56.0/58.0 in.
Length - 156.0 in.
Width - 72 in.
Ground Clearance - 4.5 in.
Weight - (assumes 427 engine and 4-speed Toploader transmission installed by purchaser) - approx. 2,500 lbs. depending upon body
Weight Distribution - Depends on engine installation by purchaser
Standard Fuel Capacity - 20 Gallons
Chassis/Body:
Type - Full-Length, 4 inch X .125 inch; D.O.M. Steel Round Tube (.120 inch D.O.M. on aluminum body chassis)
Body Material - Hand Laid Fiberglass or Aluminum
Suspension:
Front - Independent Unequal-length adjustable Control Arms, Coil Springs, 3/4" Anti-sway Bar
Rear - Independent Unequal-length Control Arms, Coil-over shocks, Trailing links, and 5/8" Anti-sway Bar
Steering - Rack and Pinion, 16" Steering Wheel
Brakes:
Front - 5/8" X 11-7/16" OD Disc, 2-3/8" Two-piston Caliper
Rear - 9/16" X 11.5-1/2" OD Disc, 2" Two-piston Caliper
Differential - 3.54:1, Shelby Aluminum Limited-slip
