Old 05-29-2003, 07:48 PM
niles niles is offline
Cobra Make, Engine: Hunter #28; 396 Cleveland stroker; more than 495 HP; TKO 5 speed
If all your asumptions are correct; it has to be plug or wire.
All you need for firing is: fuel, spark and compression. compression you have verified, mechical/ timing etc has to be OK if the other 7 cyl are normal.
Put in new plug.
If still not firing; change plug wire with one of the neighbors and see if the miss moves with the wire.
good luck
gn
