Still Working it!
Thanks for the input, I've replace the plug in the number 1 cylinder with a plug from another cylinder and then a new plug. Also same for the wire....Ive tried 3 seperate wires and still not a hint of life in number 1. I have verified the plug is sparking as it operates a timing light just fine and about put me on my ass as I removed the wire from the plug. I manualy rotated the engine to compression stroke to verify compression on No 1 lined up with the right spot on the distributer. Its a new cap and rotor. I even borrowed a buddies distributer to make sure that wasn't the poblem......Man-O-Man Im stumped on this one! Im thinking mixture in that cylinder is lean but don't know why....I have adjusted the accelerator pump arm and travel....Im reaching here!
(Grover...Thanks for the put...Jerry C. says your cobra looks real nice and I look forward to seeing it as soon as I get mine back on all eight)
