Old 05-30-2003, 03:26 AM
750hp's Avatar
750hp 750hp is offline
Longshot - but you might have a faulty camshaft that has ground the #1 lobe off. This could still allow a healthy compression test as the valves would be seated in the head. It's not likely that this is the problem, but you could quickly and easily check by simply pulling the valve cover off and cranking the motor. If the rockers are moving, at least you've eliminated one more option....
Craig
