Old 05-31-2003, 04:08 AM
BlueRooster's Avatar
BlueRooster BlueRooster is offline
Cobra Make, Engine: SPF #623 460/4x2
Default Lost my clutch completely
Since I got the car 1 month ago the clutch has gotten progressively worse, until tonight when I started the car and when I tried to put the car in gear the tranny would not let me put it in gear. I noticed that the pedal did not have full travel, so I looked into the footbox and noticed the pedal sat low. I pumped it and it didnt seem to get any stiffer or sit any higher. I had my wife pump the clutch and hold it to the floor. I opened the bleeder the comes out of the bellhousing, and a little fluid came out...it didnt seem to sputter air or anything but now the pedal sits at the floor and will not build any pressure. I am at a roadblock.
BTW it is a hydraulic clutch...everything is inside the bellhousing.
I would really like to talk to someone that has a good knowledge of clutches, if it is possible for me to call and explain this to someone in detail that would be much appreciated.
Dane
