Old 05-31-2003, 06:19 AM
jmille jmille is offline
Cobra Make, Engine: SPF 1345, 351W Stroker
Default Problem Solved
Went out this morning started her up. Perfect 7.5 psi fuel pressure reading. Took my trusty heat gun and began blowing hot air on the gage. Within a minute the gage read 2 psi. Wraped gage in a cold towel and were quickly back to normal. Pulled gage drained glycerin and left the plug out so the gage was vented. Started the engine 7 to 8 psi. No change when we heat the gage. Needle is a little jumpy without the dampening that the glycerin provided, but it reads right at all temps.
Thanks for the tip. I would have looked at a lot of other things before the liquid filled gage.
Jerry Miller
